JD 3720 vs NH TC33DA
   / JD 3720 vs NH TC33DA #1
Homeboy
Philadelphia
International Cub Lo Boy
So for a few months now I have been settled on the JD 3720 with a FEL and backhoe (300cx/448), and just went to buy it from a dealer ... who also handles NH ... and had a TC33DA with FEL on the lot ...
I had only considered the Kubota Grand L's as a competitor but liked the JD better ... so thanks in advance for for recomending Kubota and the Chinese brands, but I already ruled them out for various reasons /forums/images/graemlins/wink.gif
but now that I saw the NH I'm not sure - ignore the fact that JD has a cheaper, more comparable "3320" within their product line, because within the JD line I already decided I'd pay more for the extra power of the 3720 over the 3320 - basically, my reasons for prefering each are
JD
- prefer slightly the ergo (nice, but not huge difference)
- 3720 has 33% more horsepower for 12% more money (based upon my actual dealer quotes) - never know when the HP might be handy, even if I think I probably don't need it
- many dealers in my area
- 15 versus 25 miles to nearest dealer (not a big consideration)
- certain items (FEL bucket) seemed stronger construction
NH
- SuperSteer option (not included in current quoted price)
- includes certain items (3-point telescoping, telescoping steering wheel) not included (or available) in JD price
- 2400 versus 2900 lbs. (maybe NOT an advantage if I never end up using it for lawn work, which I currently don't plan to use it for but want to allow for down the line - I could always buy a zero turn if I add that application)
- certain items (FEL, engine access, swivel seat) seemed better designed
I know NH has more powerful models TC40..), but they are larger then the TC33DA, which is as large a size as I want - this is a key reason I didn't like the Kubota - I want a more compact package - that means I'm left comparing the JD 3720 to the NH TC33DA
(... you notice price is not a key part of my criteria, though of course the NH is cheaper).
The dealer (who seems to favor NH and stocks many fewer JD models) is clearly pushing me to the NH, arguing I'm paying for extra power I won't need, and favors my adding the SuperSteer option.
so the biggest issue seems to come down to the greater JD horsepower I'm not sure I'll need (but would gladly pay for within the JD line) versus the SuperSteer I'm not sure I'll benefit from, but certainly seems a nice feature since I have many trees ...
... and then, of course, there are all the other reasons I mentioned to consider ...
<font color="red"> </font> would you but the SuperSteer if you were buying the NH, because if I'm not I'll probably still favor JD ...
I know, the generalised "which is better, JD or NH" question /forums/images/graemlins/blush.gif but with a fairly specific set of decision points /forums/images/graemlins/confused.gif
THANKS! /forums/images/graemlins/cool.gif
   / JD 3720 vs NH TC33DA #2
Make sure you compare PTO horsepower, not gross engine horsepower. PTO horsepower is the useable power at the PTO or drawbar. The PTO hp of the 3720 is 35, while the PTO hp of the TC33DA is 27. So while the gross engine horsepower is way off (44 vs 33), the PTO hp difference isn't as large. Some manufacturers don't even advertise PTO hp because of poor driveline efficiency.
Remember with the NH you have a swivel seat, tilt AND telescoping steering, seat on an incline plane, and much better visibility. Ergo is subjective, so this is up to you.
The 300X does lift slightly more (it is a larger frame size), but the components are actually built heavier on the 14LA. The 14LA (15LA if you get supersteer) does have better reach though. As far as loader construction, look at the torque tube widths. The NH torque tube is much wider. 10 bolts hold on the NH mid mount brackets, while 4 bolts hold on the JD mid mount brackets. Not to mention an adjustable loader joystick and simulatneous raise and curl valve on the NH.
Supersteer cuts the turning radius by 40%. If you will be doing some mowing and there are some obstacles, you will definitely be happier with supersteer. Its the same idea as a zero turn mower, its going to decrease the amount of time it takes to get the job done if you can zip around obstacles or in and out of tight spaces easily. Also with Supersteer you will get a longer wheelbase 72" NH vs 68" JD (to give room for the front axle oscillating). Finally, you also get Sensitrak when you get Supersteer. Sensitrak automatically engages and disengages FWD. The benefit of this is that is protects turf (especially nice if the wife might be mowing), reduces front tire wear, and increases driveline component life (so in the end it will pay for itself!!!).
Don't forget Mid-PTO. Did the 3720 have this installed? You will need this if you ever want a mid mount mower or front snowblower. You also get flex link ends standard. And a bucket level indicator on the 14LA (opt on the 300X).
As far as engine access, both have flip up hoods but the NH has a gas strut assist instead of a prop rod. A steel subframe keeps the hood from flexing on the NH... the JD hood flexes quite a bit when in the vertical position. Also, look at the flow-through radiator on the NH, four headlights versus two, etc etc....
In the end both tractors will get the job done... but for less money and all of the features that I mentioned, I think you would be better off with the TC33DA.
pdub,
that was really helpful, thanks - I'm going to ask the dealer to add SuperSteer and Sensitrak to the quote and see how that turns out ...
Your PTO point is well taken, but 35 vs. 27 is still a 30% power difference - the main reason I care is I may buy my brother in laws PTO driven chipper, which I've been told is a huge PTO HP hog
I'm torn on whether to buy a separate mower if I ever start mowing, or to add a mower to the tractor (in which case SuperSteer would be great).
on the FEL construction, I was confused when I wrote my note - it was the backhoe bucket on the Kubota which was sticking in my mind and which was much heavier then the NH backhoe bucket - the FEL bucket on the JD and NH were about the same ...
I really appreciate your comments on the torque tube and FEL construction, something I wouldn't have known to consider ...
ciao
   / JD 3720 vs NH TC33DA #4
There's a lot of differences between those two tractors. There's nothing at all wrong with the TC33DA - I was very tempted by the TC33 early on when I first started looking at compacts. But IMO you're comparing tractors that are nearly in two different size and power classes.
Compare not just the rated PTO hp but the engines peak torque numbers, the torque rise %, and the speed at which that occurs. This will help give you some insight into how much 'grunt' each has. I couldn't come up with the numbers quickly. The 3720 has a turbocharged diesel (that tends to helps grunt), the TC33DA is normally aspirated
The 3720 has a 13.5 gallon fuel tank, the TC33DA a 7.3 gallon tank.
The 3720 has a 3-point hitch rating of 2200lbs @ 24" back, the TC33DA just 1635 lbs.
The 3720 has 13.9gpm combined hydraulic output, The TC33DA a 12.7 gpm.
The 3720 has a max. vertical drawbar load of 882 lbs, the TC33DA ?
The 3720 has front/rear axle ratings of 3197lb/5292lb (?) the TC33DA ? (I'm not convinced of those numbers for the Deere, might be a typo (sounds high on the rear axle)).
This could go on for awhile, - the point is you need to dig deep sometimes to find all the real differences. Check the brake/hydro pedal layouts, rear drive types, etc.,.
   / JD 3720 vs NH TC33DA #5
You have already got some great info. Both are great machines.
One thing. Supersteer isn't perfect. While it really helps with mowing, it is quirky for loader work. You really ought to try all three (TC33DA-SS, TC33DA, and 3720...) doing actual loader maneuvering. I am not saying you'd prefer one, just that you might be surprised. I know one owner that did some real interesting modifications on his home with a Supersteer machine, when it lurched one way when he was going the other...
Finally, there is also the Deere 3520, still turbocharges (sans intercooler) and a little between the other two machines. But you already said you aren't looking down...
Telescopic draft links and iMatch both are low cost options on Deere. They are really pushing iMatch which is why the telescopic links arfe an option.
The Steering wheel doesn't telescope, but the seat is fully adjustable instead of the inclined plane. You can raise the seat up in the far front position and down in the rear, or wherever you want. I love mine, it is a great seat, and yellow sure is cooler in the sun. I haven't tried the air suspension, but hear its awesome.
I wonder sometimes about two line dealerships. Why they end up pushing one over the other? Is it because it's better for them or you?
But both are great machines...
   / JD 3720 vs NH TC33DA #6
I bought the TC33Da hydro about a month back. I also looked at the JD 3320, but it was about $3k higher and I liked the features of the NH more. I didn't get supersteer. I really like the machine so far, but I have only used for loader and box blade work. The things I really liked on the NH:
telescoping arms
cruise control (for mowing)
skid-steer compatible quick release on loader
size and weight of machine (plan to mow some day)
   / JD 3720 vs NH TC33DA #7
Wouldn't the TC35DA be a closer comparison to the 3720?
   / JD 3720 vs NH TC33DA #8
By Hp, yes, but the 3720 is a mid chassis machine. (ClassII in Boomerish)
   / JD 3720 vs NH TC33DA #9
Actually a TC45DA would be the best comparison if you are only looking at horsepower because it is 45 hp vs 44hp. It isn't really a fair comparison though because the NH is a higher spec'd tractor. Its irrelevant anyway, since Homeboy wrote that he was aware that the 3320 would be a more fair comparison to the TC33DA.
The 3020 series isn't really a "class II in Boomerish" tractor, it is somewhere in between NH's class II and class III, in terms of frame size, weight, and basic specs. It sure is hard to find an "apples to apples" comparison nowadays!!!
Anyway, since the basic question that started this discussion was whether or not Supersteer is worth the money, I would suggest that you (Homeboy) go the the NH forum and ask for advice from Supersteer owners, i.e whether they are happy with the performance, reliability etc. This would probably give you better feedback than listening to a bunch of us who don't own Supersteer (although I have used a SS TC33DA multiple times).
   / JD 3720 vs NH TC33DA #10
Excellant point! Talk to owners but most importantly try one yourself. I am not an owner because I did, yet, others may LOVE it! Your mileage may vary!
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
2013 Ford F-550 Ambulance (A50323)
2013 Ford F-550...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
2017 CATERPILLAR 259D SKID STEER (A51242)
2017 CATERPILLAR...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
