JD 4030 air conditioning compressor not engaging
   / JD 4030 air conditioning compressor not engaging
The terminals burn in the connector. There is two power wires to the top of the cab from the connector. The blower motors on low speed split the power through one motor then to the 2nd motor from one wire to run at half speed. On high speed each blower has its own power. If there is no power for the AC clutch and one blower motor on high, one of the power wires has no voltage.
You hit it on the nose. Initially I was thrown off by the power at the blower switch, until I found out that there was power also coming from the right side blower into the blower switch to run the left blower on the low setting. As I was tracing it back to the tractor firewall, I found the wire that burnt in the connection. Fixed that and i was good to go.
Thanks for all the help!
Jeff
   / JD 4030 air conditioning compressor not engaging #12
Glad I could help.
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
1994 SUNDOWNER 4 HORSE GOOSENECK TRAILER (A52708)
1994 SUNDOWNER 4...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
1026A (A58374)
1026A (A58374)
Forklift Telescopic Boom W/11ft Extension (New/Unused) (A59225)
Forklift...
PALLET OF CHAINS AND BINDERS (A58214)
PALLET OF CHAINS...
