JD 413 Rotary Cutter opinions
   / JD 413 Rotary Cutter opinions #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
Hi All,
Can anyone give me some feedback on the 413? I have a 20HP Yanmar (sorry guys : )) as well as a ZTR to do my grass cutting. I want to use the 413 to cut the thick pasture grass that surrounds my lawn area. What do you think? I don't have many trees (saplings) to cut down, or forest to reclaim, so I don't think the fact that it is light duty should be a big problem. Any one used one of these?
Cheers,
Rob
   / JD 413 Rotary Cutter opinions #2
They are very light duty....I have a 513 bought it new and after about 2 weeks it was all bent to heck.....I had to do a lot of reinforcing and it is a good brush hog now....basically they will not take much abuse.
   / JD 413 Rotary Cutter opinions #3
I had the same experience as Cactus, with my 513. For grass, they are great. If reinforced so you can back into brush, they are great.
Backing up, because they have a steel curtain across the back rather than a chain 'curtain', it can dig into the dirt a bit and get bent. If me, I would weld some support on a new one right away, before getting it bent up, making straightening it out more difficult. I trimmed the lower edge around the back with 1" square tubing, and that has made a good, rugged rotary cutter. The rest of the cutter is well built and I suspect you will like the 413 real well for the tasks you want to do.
   / JD 413 Rotary Cutter opinions #4
The 513 cuts very very well,it just needs reinforced.
by the time I got to the store with the usd one, it was gone. thanks for the quick responses.
Cheers,
Rob
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
(INOP) 2019 CATERPILLAR 336 EXCAVATOR (A51246)
(INOP) 2019...
1991 Mack RW713 Day Cab Truck, VIN # 1M1AY10Y4MM005693 (A51572)
1991 Mack RW713...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
