Egon
Epic Contributor
Get some oil on those linkages and find out how loose they are before you get too excited.:thumbsup:
Is the drop more noticeable at lower rpm's?
Your tractor comes with a 1-spool or 3-spool monoblock valve attached to
the main gearbox's right upper side. Normally, hydraulic pressure to operate
your valves goes from your implement pump to your factory valve(s), and
then from that valve's PB port to the 3-pt cyl valve. If you add an
aftermkt valve, it must be plumbed in series with the other valves, or get
its hyd power from a diverter. Since your Danfoss valve does not use
its PB port, it should be plumbed off a diverter. If it is not, its OUT
port (which is not designed to handle high pressure) may be plumbed to
the IN port of the SCV(s) or the 3-pt, which is not correct.
Something does not seem right here.
It does work until the pressure is equalized.
How much movement do you think that would take ? 1/2" ?
I agree, but think the hookup is what's causing his leakdown problem.
I also need the rod ends (see pictures at begining of thread) that connect the joystick to the vavle.
