JD 4310 E-HYDRO won't move
   / JD 4310 E-HYDRO won't move
As a I said when I passed throttle step a new flash code appears (**-*) flywheel sensor
In the manual when this code appears in calibration mode that means engine speed is not in range and you have to adjusted
My question how to do for adjusting it to 950 rpm at low idle and 2810 at high idle?
thanks
Hi
As I said Ihave only problem about forward and reverse proportional valve. After checking coil resistance and continuity to controller that are good. I tried to measure the current from controller to coil and I find 0mA the manual shows that must be 950mA in BOT
Then I note that module doesn't respond to pedal or there is something that prevent controller to provide current to coil !!!!
Hi,
I launch calibration all steps are good until I arrived at reverse proportional valve and no response!!!!
Hi,
Finally, the tractor works after I change the Flywheel Speed Sensor and make calibration
thanks to all people that helps me
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2016 STOUGHTON 53FT DRY VAN (A57880)
2016 STOUGHTON...
2002 Club Car Carryall 2 XRT Gas Utility Cart (A55851)
2002 Club Car...
John Dozer JD650 (A51691)
John Dozer JD650...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
2017 MOROOKA MST300VD CRAWLER DUMPER (A52707)
2017 MOROOKA...
