JD 4310 mid-PTO shuts off during use?
   / JD 4310 mid-PTO shuts off during use? #1
tbestor
Stewartville, MN
John Deere 4310
I have a JD 4310 compact utility tractor. When mowing with the belly mower, the PTO disengages. I can usually get about 30-45 minutes out of it, then it seems to warm up and the PTO shuts off. If I wait for 10 minutes, I might get 5 more minutes of mowing. Then the PTO stops turning on altogether. The tractor motor works fine- no overheating or lights. My guess is some sort of electronic component is heating up and turning off the electronic PTO. Thoughts?
Thanks Tim
   / JD 4310 mid-PTO shuts off during use? #2
Welcome to TBN,
The mid (and rear) PTO is activated by a solenoid valve (#42 and 53 below), you can can check the connections to it, and also the resistance of the coil. Might be time to get a tech manual for your machine if your going to do your own wrenching, at $70ish they are worth their weight in gold.
Mid PTO Kit, Optional
Cart key PART NO. PART NAME QTY SERIAL NO. REMARKS
1 YZ81107 Cylinder 1 MID PTO ACTUATION
2 H21957 O-Ring 1
3 F37020114 O-Ring 1
4 YZ81108 Shaft 1 MID PTO SHIFTER
5 YZ81132 Spring 1
6 19M7803 Bolt 4 M8 X 70
7 YZ80162 Bushing 2 LOCATOR
8A YZ81080 Housing 1 ORDER YZ81450
8B YZ81450 Kit 1 Mid PTO Housing
9 19M7868 Bolt 1 M8 X 30
10 YZ81451 Kit 1 SHIFTER FORK
11 F7112512MWK Spring Pin 1
12 YZ81415 Fork 1
13 YZ80777 Gear 1
14 F3901078 Snap Ring 1
15 F40104 Ball Bearing 1
16 F39000168 Snap Ring 1
17 YZ80089 Universal Driveshaft 1
18 F65282 Seal 1
19 YZ80139 Plate 1
20 CH16469 Pin 2 PTO COVER
21 19M3147 Cap Screw 1 M10 X 35
22 F37030213 O-Ring 1
23 F40306 Ball Bearing 2
24 F39000281 Snap Ring 1
25 F21029 Cap 1 EXPANSION
26 F39000187 Snap Ring 1
27 YZ81273 Bearing 1
28 YZ81236 Drive Shaft 1
29 F5531828 Thrust Bearing Race 2
30 YZ80776 Gear 1 Z=27
31 F5101816 Needle Bearing 1
32 F7112524HBK Spring Pin 1
33 YZ80492 Pin Fastener 1 STUB
34 F21021SC Cap 1 EXPANSION
35 F39000206 Snap Ring 1
36 F21037SC Cap 1 EXPANSION
37 F40304 Ball Bearing 1
38 YZ80775 Gear 1
39 YZ80781 Pin Fastener 1
40 YZ81235 Gear 1
41 ...... Nut 1 (ORDER YZ81312)
42 YZ81353 Solenoid Valve 1 (W/ 2-PIN CONNECTOR)
43 YZ81305 Grinding Tool 1 (USE WITH YZ81312)
44 61M5015 Elbow Fitting 1
45 51M7040 O-Ring 1 9.300 X 2.200 mm
46 38H5015 Elbow Fitting 1
47 T77814 O-Ring 1
48 51M7040 O-Ring 1 9.300 X 2.200 mm
49 38H5001 Adapter Fitting 1
50 T77814 O-Ring 1 1/4"
51 61M5001 Adapter Fitting 1
52 LVA11276 Hydraulic Hose 1
53 YZ81312 Valve 1 (W/ SCREEN)
54 F40302 Ball Bearing 1
55 YZ81268 Power-Takeoff 1 MID PTO
56 RE73096 Relay 3
57 M139089 Cover 1 PTO SHAFT
58 LVB25291 Kit 1 MID PTO
   / JD 4310 mid-PTO shuts off during use? #3
Sorry, having trouble with inline pictures and tables this evening :(
Thanks. I saw the three solenoids sitting side by side on the underside of the right fender/housing area, and wondered if one of them may be the culprit. I will try putting a test light on each one while the PTO is operating (no mower), and then again when it stops. Maybe I can isolate the bad one that way.
Thanks again.
   / JD 4310 mid-PTO shuts off during use? #5
It looks like In upper right of drawing BOX 11, it's the third solenoid key 13 part number YZ81353
John Deere 8560 (A53314)
John Deere 8560...
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
Bigfoot Metal Stand Up Sign (A55758)
Bigfoot Metal...
New Holland 36 Flail Chopper (A50775)
New Holland 36...
Kubota BH92 Backhoe Mounting Brackets (A50775)
Kubota BH92...
