JD 440 ID with 2-53 Detroit wont start
   / JD 440 ID with 2-53 Detroit wont start #1
rolandj
NJ
1960 JD 440 ID, 1999 John deere 445 lawn tractor w/ loader, 2004 Kubota bx 23
So about a month ago I started the machine and it started up I used it then parked it. I went to use it in recent snow storm and wouldn't start. Its like the throttle linkage is stuck closed because I gave it a shot of ether and it fired and idled a second but was like it was choked out. I sprayed all by the throttle linkage. I was reading something and almost seem as though something runs up and is controlled under vavle cover. I am wondering if something is hung up. I put heat on the tractor. it happened one time last year in the cold. I am confused.
   / JD 440 ID with 2-53 Detroit wont start #2
First plug in the block heater. The S series 2-53 used in the 435 and 440 was a dismal cold starter. When rebuilt with the N series piston and sleeve set along with C35 injectors . Starting is much improved .
It does would like a no fuel problem on your tracror . Is the fuel rack free to travel?
Worse yet if the engine does start and the rack is stuck. Zrrrrrrrrooooooommmmmm
I assume if I pull valve cover I would be able to see that.
2011 FORD F-450 (A52472)
2011 FORD F-450...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2018 RoGator 1100C (A55314)
2018 RoGator 1100C...
COOLTECH 34288 (A55745)
COOLTECH 34288...
