JD 4400 Thermistor Issue
   / JD 4400 Thermistor Issue #1
kellygulchgardens
pinehurst, ID
John Deere 4400
Hi Everyone, My JD wouldnt start a few weeks ago so I started reading threads and found out about the thermistor. I replaced it and it ran beautifully. For about a week and now its down again. I was driving it and It pretty much sounded like it ran out of fuel. Now its having the same thermistor issue as last time. Cranking but not turning over. I ordered a few more thermistors but they wont be here till tuesday next week. I checked the thermistor that I had installed and it looks fine.
My question is could there be something else burning up or breaking the thermistor? Something that I need to replace when I put in another new thermistor.
Thanks
   / JD 4400 Thermistor Issue #2
Welcome to TBN. The pesky thermistor again. Will do some searching, but others may beat me to a helpful response.
Cranking but not running maybe? Just thinking if it cranks, then it is indeed turning over, but only under starter power.
My limited understanding of the thermistor is that it only functions with the fuel solenoid upon startup... and is out of the picture after engine is running. So thinking it may be something else shutting off your fuel.
   / JD 4400 Thermistor Issue #3
Check your relays and fuses too...and your fuel filter.
Another thing to consider is if your starter is turning fast enough...
16001 (A55853)
16001 (A55853)
PALADIN INDUSTRIAL SCREENER (A58214)
PALADIN INDUSTRIAL...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
2024 Timpte 40ft Hopper (A56435)
2024 Timpte 40ft...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
