JD 455 keeps rolling forward after pedal is released
   / JD 455 keeps rolling forward after pedal is released #11
I had the same issue with the 455 I purchased used with 1600 hrs where it would roll backwards. I didn't think it was the neutral adjustment either and stayed focused on the linkage assuming the problem was there, mostly because watching it pedals it looked like it was slow to return. Finally one day I printed off the section of the manual describing the adjustment and went to it. Took about 20 minutes- jacked up the lowered onto 2 jack stands, removed the right rear tire, and started the engine. Making small adjustments and locking the jam nut each time I got mine dialed in to zero rolling now. Should have done it right when I got it.
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A53472)
NEW 2022 Load...
Adams 8 Ton Weigh Hopper (A53472)
Adams 8 Ton Weigh...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Electric Concrete Mixer (A51573)
Electric Concrete...
Modine Shop Heater (A51573)
Modine Shop Heater...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
