BleedingOrange
Veteran Member
- Joined
- Apr 19, 2011
- Messages
- 1,048
- Tractor
- Kubota BX 2370
To the OP, did you ever find the problem ? I don,t believe the 455 has a PTO clutch. It,s all hydraulic driven. When you active the switch, can you feel the coil in the rear activate ? If you get 12V to the coil, the coil should energize and do its thing. Make sure the other wire has got a good ground on it. You need to have that as well.
