JD 4600 Front Hub Seal Replacement
   / JD 4600 Front Hub Seal Replacement #1
zdutchman
MI
JD 4600
I have a 4x4 Model 4600 PowerReverser with a leaking right front hub seal. I removed the hub and checked on the local dealer site, where oil seal #35 on the schematic shows to be part #LVA14181. I ordered the oil seal from my local JD dealer but when it came it the replacement seal is a double lip design whereas the seal I removed is a single lip design. I asked the parts guy about the difference, he said it's possible that the double lip seal is a design improvement, but he doesn't know for sure. I paid $39 for the seal, so it's not like I'm ok with giving it a try and then replacing it if it's the wrong seal. Anyone have any experience with this subject?
   / JD 4600 Front Hub Seal Replacement #2
I'd rather have the double lip in that environment.
   / JD 4600 Front Hub Seal Replacement #3
Agree with Harry -double is better than single here so long as the dimensions are the same
   / JD 4600 Front Hub Seal Replacement #4
I guess if I had to choose, then I'd lean toward the single lip for things that see a lot of dirt, not much water, and aren't protected with felt wipers. That would be most axle seals or hydraulic cylinder seals.
But I also don't think it makes much difference. If it were mine, I'd use the seal you have in hand if it fits.
rScotty
   / JD 4600 Front Hub Seal Replacement #5
JD Parts shows your original part #LVA14181 and what appears to be an upgraded "Seal Kit":
#35
Seal Kit
Part Number SJ14405
Description
Seal Kit - SEAL KIT, SEAL,FACE
That may be the double lipped seal you have and it may or may not require the upgraded housing.
See illustration numbers #32 & #35 on the IPL.
The 'Housing' #32 is to the left of #33 in the screenshot you posted
You should go past the Parts Desk to the Service Desk and seek confirmation.
   / JD 4600 Front Hub Seal Replacement #6
seal kits LVA14181 or SJ14405 question . the SJ14405 I ordered by mistake I think? consists of two identical seals with outer orings.Before I disassemble the hubs would like to be clear which are the correct seals. No help from my dealer and no instructions in the shop manual. 2004 4710 tractor. Is the SJ14405 only for a newer model housing? any help appreciated
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
