JD 4600 HST sluggish when changing directions
   / JD 4600 HST sluggish when changing directions #11
I just purchased a 4600 HST and mine acts the same way you describe here. Let me know what you find out.
My problem wound up being the Hydrostat pump. I took it to the local JD dealer and they tore it down and sure enough you could see how worn the pump was. I haven't received th total bill yet but the pump rebuild was to be around $2000 t0 $2500. The good news is the tractor is back to running.
   / JD 4600 HST sluggish when changing directions #13
How many hours did the tractor have on it for the pump to be worn out?
We bought this tractor used. It presently shows 1073 hrs. on the hour meter.
   / JD 4600 HST sluggish when changing directions #16
Lube everything up real good.
   / JD 4600 HST sluggish when changing directions #17
My JD 4600 tractor had only 1,080 hours and apparently this sluggish symptom was very unusual. The pump tested fine. My John Deere dealer ended up replacing the hydro control and piston. The tractor had to be split and required special tools to do the work. The bill for parts and service was over $4,000. It works fine now.
   / JD 4600 HST sluggish when changing directions #18
Ouch, well at least it fixed it!!
16 BLADE DISC HARROW, 3PT (A52708)
16 BLADE DISC...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
Giyi Mini 4-N-1 Bucket (A57149)
Giyi Mini 4-N-1...
