JD 50 Steering problem
   / JD 50 Steering problem #11
The rollomatic front end was designed to make the steering easier, not harder.
If you ever had to work plowed ground or uneven ground with the traditional front end, you would see the difference real fast. Worked tractors with both.
Thanks beenthere I have driven more Farmalls than John Deere two cylinders. So I have limited experience with 2 cylinder steering. Thanks for your advice. This advice will save me the $585 - buying a non rollamtic front end, All the tractor pullers want the non rollamatic front wheels. This information came from a JD Salvage yard owner. Also I found out that one of my front wheels has bad wheel bearings. The wheel bearings in the other front wheel are not the best - thus one of my next projects.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
Freighliner Tender Truck (A56436)
Freighliner Tender...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
