JD 5075 Steering Wheel turns freely after tires stop turning
   / JD 5075 Steering Wheel turns freely after tires stop turning
Real John Deere WSM's are the best in the business.
The one in the link even has JOHN DEERE misspelled as JHON DEERE.
I would stay away and go for the real one regardless of $
Dave M7040
Solid Advice. Will do.
   / JD 5075 Steering Wheel turns freely after tires stop turning #12
Not sure if this is applicable, but...
A few years back, some of the 50xx series had reports of melting fuel tanks. You might be able to search some of the old threads here.
I believe the melting tanks were caused by overheating hydraulics, something about a mis-adjustment on a _______(?). When the 3 point hitch was raised too high it would keep trying to lift, operate a relief valve, which would overheat oil, melt tank.
Could same issue show up as problems elsewhere?
When I raise my 3 point hitch to the very top, I then lower it a couple inches and check if I hear any change to hydraulics to make sure relief valves aren’t unnecessarily operating.
Thanks CobyRupert, I've checked the 3 point hitch and it seems to be functioning properly
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
12ft Bushog Batwing Mower (A51573)
12ft Bushog...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
