JD 5205 hydraulics
   / JD 5205 hydraulics
Follow up on JD 5205-dropped oil, changed external filter and removed and cleaned internal screen. The screen was all clogged up. It runs like a new one!! FEL functions are quicker...it totally fixed the problem. I did check suction line and connections first, but all were tight. Thanks for some excellent "over the shoulder" help.
As for 450C loader, I had planned to pressure test pump and system relief valve, but pump is real loose in housing, so I think that is problem. Will check rest out first because pump is $1600+ new. I hope it is not relief valve--it is drott (has 4/1 bucket) and it appears parts may be hard to get--either entire valve or repair parts. I was told by JD dealer that Ford (now NH) had purchased drott from Case and had parts, but that may have been bad info--local NH dealer does not seem to know anything about that...!! So, the saga continues...Thanks guys!! :thumbsup:
   / JD 5205 hydraulics #12
If the pump shaft has play off axis then it is shot. How is the pump mounted? If it is via a coupling I would certainly consider an aftermarket pump for a whole lot less money. Same would be true for the valve with pr built in. I am a fan of Commercial Shearing pumps and motors and would suspect you can match one up very close to your pump. For an older piece of equipment I would look for a match at Surplus Hydraulics.
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
