JD 54" bucket cubic yard capacity
   / JD 54" bucket cubic yard capacity #1
deere_x475guy
Eaton Rapids, MI
JD 4110
JD 54\" bucket cubic yard capacity
Hi everyone, I thought that I remember seeing some place that the cubic yard capacity was 1/3 of a yard. Do any of you know if this is true?
   / JD 54" bucket cubic yard capacity #3
Re: JD 54\" bucket cubic yard capacity
Found this on the web at Stonehams. This is from a 200CX loader. Are other loader buckets similar? BTW, 1 yd = 27 cu. ft.
Hope this gets you close.
BUCKET SPECIFICATIONS
Bucket Type
Width
Struck Capacity
Weight
Materials Bucket
1250 mm (49-in.)
0.17 cu. m (6.0 cu. ft.)
70.2 kg (155 lb.)
Materials Bucket
1350 mm (53-in.)
0.22 cu. m (7.8 cu. ft.)
82.9kg (183 lb.)
Materials Bucket
1550 mm (61-in.)
0.25 cu. m (9.0 cu. ft.)
86.1 kg (190 lb.)
   / JD 54" bucket cubic yard capacity #4
Bucket Type
Width
Struck Capacity
Weight
Materials Bucket
1250 mm (49-in.)
70.2 kg (155 lb.)
Materials Bucket
1350 mm (53-in.)
82.9kg (183 lb.)
Materials Bucket
1550 mm (61-in.)
86.1 kg (190 lb.)
   / JD 54" bucket cubic yard capacity #5
Has anybody ever monitored or measured the differences between level filled buckets, which I assume the above numbers are, and heaped buckets? 1/3 of a cubic yard sounds about right for 53" with a little heaping.
We need someone to perform a science experiment of moving a known pile size from one location to another keeping track of number loads it takes with a healthy amount of "heaping" - good ballast is assumed. Surely, with all the new owners looking for seat time, this shouldn't be a problem. I would but I can't seem to get the dirt man and weather aligned yet...
   / JD 54" bucket cubic yard capacity #6
Thanks bglombowski yes it does. I seem to recall thinking that 3 buckets would get me close to a yard.
I have to move fill from the back of my property to the front of my home to take some of the steep grade down. Going to be a lot seat/loader time. I will probably post something in the projects folder with pics.
Thanks again
Thanks again
MAYTAG ATLANTIS WASHER & DRYER (A54757)
MAYTAG ATLANTIS...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52707)
2017 FECON RTF140...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
2013 RAM 4500 (A50323)
