JD 5400 Joystick Repair
   / JD 5400 Joystick Repair #1
HarmonyFarmWV
Morgantown, WV
JD5400
Howdy Ya'll?
I have a JD 5400 with the 540 Loader Hydraulic Setup.
The pistons (Part RE55057) broke and I am having trouble with the repair.
I found this thread:
[Removing JD 540 loader Joystick mechanism to replace broken valve controllers]http://www.tractorbynet.com/forums/john-deere-ag-tractors/300893-removing-jd-540-loader-joystick.html[/URL]
And have tried to work through the repair but I am having trouble figuring out how to remove the piston.
Here are the diagrams that I found:
70-15-6 From the Technical Manual (TM1520)
View attachment cables.pdf
From the Parts Catalog:
View attachment joys1.pdf
Here is what the Joystick Assembly looks like
I removed these
Snap Rings from behind the nuts. But the nuts still don't come off. Am I missing something? I looks like there might be 2 sets of snap rings per piston, is that true? Is there anything else holding them in place?
Thanks for your help!
   / JD 5400 Joystick Repair #2
Not sure if I can be much help, but I believe you need to remove the locking mechanism first before the pistons will come out. Parts 11 thru 18. I think you need to drive out small roll pin first(#17). We usually install complete joystick assembly when a customer has issues with it since labor costs plus parts will be at or near cost of complete joystick anyway. Also have seen failure of plastic housing after replacement of pistons, so for us to warranty the work, we prefer to install complete assembly.
Thanks, solid advice. I removed the locking mechanism. Is the same procedure recommended for removal of the whole joystick assembly? Disconnecting at the pistons? Or somewhere else?
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
MMS MS36C Skid Steer (A57149)
MMS MS36C Skid...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
LOT: (1) Pallet of Chains (A59076)
LOT: (1) Pallet of...
2021 Ford F-350XL (A57148)
2021 Ford F-350XL...
Hydraulic Dingo Concrete Mixer (A55272)
Hydraulic Dingo...
