JD 5415N
   / JD 5415N #13
Then there should be water in oil ?
Depends on where it blows and where the pressures are. Could possibly be a crack in the head or block as well, if it's near where oil pressure is, that is under more pressure than the coolant system and that's why it's not getting coolant in the oil.
   / JD 5415N #14
Ditto leak could be leading to combustion chamber & coolant going out muffler
   / JD 5415N #16
Is it a wet sleeve engine? Could be a liner failure and leak oil into coolant. But that fast, quite unlikely.
   / JD 5415N
I ordered some parts and 1 off them came with a short bolt with lock-tite on it. Mybe that s my problem ?
   / JD 5415N
I went and tested this tractor this morning and no oilleak to the radiator.
I do beliefe that the locktite on that 2 short bolts did the trick.
   / JD 5415N #19
Thanks for update. I'm glad you got it repaired.
Jim
Kubota RTV500 (A47384)
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2005 International 4200 VT365, Super Cab (A52384)
2005 International...
