JD 5510 loader control box not working
   / JD 5510 loader control box not working #11
found the valve body, the cylinders don't move in and out when I use the joystick, but this one appears to have covers/caps over the rear of the cylinders so they could be moving internally. Anyone have a parts diagram for the valve body? There are a few large bolts that are accesable and I miht be able to pull them to see inside if I knew where they went to -
Also, where's the sump screen / hydraulic screen on this guy?
Try here: John Deere - Parts Catalog
(Sometimes my posted links aren't "hot" and they won't click and go - just paste it in your browser.)
You should be able to get an "exploded" view of your tractor, too. At least, you should be able to find a diagram that illustrates where the sump is located on your machine.
AKfish
Thanks for the help, looks like it was frozen. Temps came up and it's doing fine. Will change out all the hyd fluid as it must have some water in it.
   / JD 5510 loader control box not working #13
kavik
Are you in Alaska?
Where?
Glad to hear you are back in business. So now you see what is working and what wasn't working before?
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
New Holland WorkMaster 37 (A53317)
New Holland...
