JD 567 round baler
   / JD 567 round baler #11
There is one for sale down the road from my house,no info.just stop and got a pic. Way to much baler for my tractors. I bet that jx80 would sure feel it back there.
That JX80 @ 62 pto HP will have more than it wants if the pressure on the baler is run at 2 o'clock and the bale is 6 ft tall. My 120 pto hp tractor knows my JD 467 is behind it when I'm going 6 MPH baling.
i have no doubts the jx80 will pull it in 2 or 4wd drive as it was being pulled by a 7710 2wd 84hp.
   / JD 567 round baler #13
That's the same HP as my Kubota and my 5x4 is just what it wonts.I could possibly move a 567 so I could mow where it was setting,lol. I paid 21,000 new with net for my 5410,the bales work out good for me...
   / JD 567 round baler #14
I thought Vermeer 5410 were advertised to only require 40 pto HP?? JD states 75 pto HP as minimum for a 567 and that would be on fairly level ground.
   / JD 567 round baler #15
On most my hay pastures,the 7040 is perfect match to the 5410(has alittle extra) but I have on hills pulled it down to were I have had to drop it in 3 low,thats with almost a full bale. Flat ground yeah 40hp will do it but my thoughts your not going to run much speed with it,cause your going to have to run in a low range gear...
7040 Kubota / Vermeer REBEL 5410 (1) - YouTube
7040 Kubota / Vicon cutter - YouTube
I was finishing up last year and this was a little patch,desided to make couple videos.I usually straighten my cuts but just went with it for the video,so wouldnt just see the front of tractor the whole time,slowed down on both also. Thats the 2009-M7040 baling and the 2012-M7040 cutting
   / JD 567 round baler #16
Do you run your 467 with your M7040, Jim?
I've been looking (dreaming about...) at the 456-457 silage special balers with net wrap. Book says 55hp. Thinkin' with 40-45% moisture bales my 60hp 5075M won't have enough "snort" to do the job!
Now, I'm thinking maybe a good, 2750 or 2755 would be a better round baling tractor.
AKfish
   / JD 567 round baler #17
AK, We had a 2755 on the farm for a few years and they are one of the best tractors Deere ever made. I wish we had it back. Ken Sweet
   / JD 567 round baler #18
Do you run your 467 with your M7040, Jim?AKfish
No my JD 4255 has been my baling tractor since I bought it in '93. In 2 to 4 rd bale/acre hay I rake three 9 ft cuts together and sometimes one can hear my 120 hp tractor grunt while baling. I just bought the M7040 about 4 months ago. I use it to load/unload rd bales,pull my Vermeer 7030 disc cutter & backup tractor for my H&S hi-cap rake. All this depends on IF I get enough rain to make hay.
I think your 5075M will be borderline but should handle a 457 rd baler making silage bales.
   / JD 567 round baler #19
Ken
Without a doubt JD 55 series tractors are some of the best ones that ever wore the JD logo.
   / JD 567 round baler #20
You get the baler?
I got to figure out if LIME is the best thing for me to invest in this year. What's you yalls opinion on getting my production out on a field?
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
48" X 36" ALUMINUM & PLYWOOD ROLLING TABLE (A58374)
48" X 36" ALUMINUM...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
