JD 5X10 Clutch Repair
   / JD 5X10 Clutch Repair #1
JD5210
Veteran Member
Virginia
5210 MFWD
The clutch is almost gone and no adjustment left on my neighbors 5410. He is trying to decide if he should have it done or do it himself. He would replace the whole clutch packet/assembly. He has the tech manual, a concrete surface to do it on, jacks and I think all the wrenches/sockets needed. He would also replace the pilot and throw out bearing.
I have read you need 2 special tools needed to disassemble. reassemble and adjust the clutch. JDG1337 for assembly and disassembly, and JDG1375 for adjusting clutch fingers.
If anyone has done this before. I would appreciate you sharing your experience, any input and pictures on it went.
Thanks in advance for your help.
   / JD 5X10 Clutch Repair #2
All the ones I have done you don’t need to adjust anything. Just put it in. It comes set where it needs to be.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A52748)
2016 RAM 5500...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
