Planters JD 71 planter
   / JD 71 planter #1
drz400
Upstate New York
'05 JD 3320
I just picked up a JD 71 single row planter.It has the corn hopper and a few corn plates.Other than corn , will this set-up also plant bush green beans with maybe a different plate?
   / JD 71 planter #2
One of your corn plates should work great for your beans. Just put some seeds in and lift your three point up and try it out.
   / JD 71 planter
I just put my seed order in.I'm waiting for it to arrive. If I measure the seeds(beans) length-width-and depth, can I fit that to a plate with that size cell opening ??? You say the corn plates will also work for beans?
   / JD 71 planter #4
Least complicated way I've found is to simply take a seed and fit it into the plate cell. If it fits, it'll usually work. Oblong seeds like green beans, I have better luck when the cell is SLIGHTLY larger than the seed. Corn likes a fairly close fit. You can measure the seed also. Lincoln AG will list cell size for their plates on the website. I've taken a Dremel tool to a couple corn plates to get a better fit with beans, however, the correct fit, requiring no modification can be found with the right sized plate.
   / JD 71 planter
It sounds like its easy enough to do. Since I work in a machine shop I can fit the seed to a plate. Can't wait till the snow melts so I can try this planter out! Thanks !
John Deere 693 Corn Head (A50514)
John Deere 693...
Informational Lot - Shipping (A52128)
Informational Lot...
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
19008 (A48082)
19008 (A48082)
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
