JD 750 (1986) Tachometer
/ JD 750 (1986) Tachometer #1
cdober
Harmony, ME
Deere 750
I have a 750 Tractor with a broken tach. It's beyond any hope of repair - I opened it up a couple of years ago to see if there was any hope and found it pretty well destroyed internally. It appeared to have jammed and then stuff broke loose. At some point the cable broke too, but that's the least of my concern, they're readily available.
Since then I've looked off and on for a replacement, but it appears there is no chance of getting another for anything under a few hundred bucks. Not a chance I'll pay that...
Does anyone have a recommendation for a particular aftermarket unit that can be installed without too much hassle? I've looked on eBay and Amazon at the myriad offerings of tachs and - where do you start? I mean beyond the 3K rpm and bezel size (2-3/8" / 60mm). I'm not worried about the bezel size too much - I replaced the instrument panel a while back with a custom made Lexan plate. I had bored it for the original size but it would be fairly easy to enlarge the hole a bit. I'm more concerned with the pickup method, what works well?. I'd also like to have an hour meter, but is it possible to get one that can be set to the existing hours, and will the hours accrued be retained if the battery is disconnected?
Thanks in advance for any good info!
Cliff
/ JD 750 (1986) Tachometer #3
Cliff
Try Hoye Yanmar Parts on the Yanmar forum. Should be a unit to interchange.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2019 Ford E-450 Shuttle Bus (A61568)
2019 Ford E-450...
CAT Chassis Only (A59076)
CAT Chassis Only...
Decorative Dinner Bell (A61569)
Decorative Dinner...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
