JD 750 backhoe
   / JD 750 backhoe #11
Thank you. I'll keep looking.
Matoyan, I went thru the same thing, I finally got fed up. The hoes I found for my 4200 was fairly high, wasn't all there or a long ways from home. I broke down and went aftermarket with a woods bh6000 with thumb. Subframe mount. I have a lot of work lined up for it, irrigation lines to trench for the paddocks, water troughs and the ponds. A sewer line to fix, small trees, brush, and scrub to clean up, so I could justify buying new. It was 7750 installed with the thumb. There supposed to put it on when I get home from my hitch here at work. I plan on doing a full thread on it when I get using it. Hope this will help. LUTT
   / JD 750 backhoe
Please let me know how it works out and please take lots of pictures. Thanks.
   / JD 750 backhoe #13
I'll second checking out Woods Backhoes. I just got a BH70-X for my JD 790. Wanted the JD #7, but no longer available, and no thumb. I see on an older Woods matrix, attached, that they list the JD 750/790 as using the BH70-X and 80. I like the BH70-X, it looks great, right size, for this sized tractor, they painted it green, uses a tractor mounted sub-frame.
   / JD 750 backhoe
I can get a D100 pretty cheap and I'm wondering if my JD750 handle it and is it something I can modify to fit on the tractor?
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
40ft Sea Container (A52384)
40ft Sea Container...
