jd 790 front axle leaking oil
   / jd 790 front axle leaking oil #11
I can search when home.drankin in the outer banks now. Be home sunday
   / jd 790 front axle leaking oil #12
DMS,
I was talking with my local JD mechanic about broken front gears on the JD770/790. He said that he has seen several over the years. In his experience, the most common scenerio was running the tractor in MFWD and having the front wheels come off the ground for whatever the reason (bump; digging down with loader; etc.) and then making contact with the ground again with the front wheels still spinning. Something had to give - and it was usually the front gears.
Do you have your rear tires filled? If not, you can do it yourself. There are threads on these forums that describe how to do it.
Bruce
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2842 (A54757)
2842 (A54757)
UNUSED JMR 40" HYD ROCK GRAPPLE BUCKET (A54757)
UNUSED JMR 40" HYD...
2014 Ford Explorer SUV (A53424)
2014 Ford Explorer...
