JD 790 front end problems
   / JD 790 front end problems #1
DWCox
Northen Virginia
John Deere 790
Hi,
Last year I chewed up the pinion and large gear in the front end (the final gears which drive the four wheel drive). I chatted with the JD tech and he indicated that they were having some incidents of this with the 870 and that they were advised that sufficient ballast in the back was considered the culprit.
After about a year, the same problem recurred--this time on both sides. I have gone out of my way to keep it out of four wheel drive except when absolutely necessary, but unfortunately the time when I need four-wheel is when I have a bucket of materials from my pond and have to back up (I keep a 400lb box blade attached when doing loader work).
I know exactly what is happening; in those instances the weight is over the front axle forcing the front gears to be the primary drive and it is just too much for it. The tech said that I could try adding even more weight to the rear (though 400lbs at the 3 point hitch is what is recommended for ballast as counter for this 300 loader). My rear tires are liquid filled. He also recommended leaving it out of 4x4 if possible when digging withe the front bucket (the pawing of the front wheels and then engaging stresses the gears).
Does anyone have any other ideas. While I do all the work myself, the parts are very expensive. I really love this tractor and have no desire to upgrade (the tech did say the 990 and 400 series do have more stout gears in the front and this problem would not happen at all).
Again, any suggestions or thoughts would be appreciated. At this point I am going to fix it tomorrow, add two five gallon buckets of concrete to the boxblade for more counter weight in the rear and continue to try to be careful when in four wheel drive. But I do have to use four-wheel drive--after all that is why I bought the tractor!
   / JD 790 front end problems #2
Sorry to hear about your problems, DW.
Which gear set went out, the center differential or the ones out at the ends of the axle?
I tend to leave my 870 in 4WD unless I'm on the road (seldom) and I've never given it much thought. I did pull a few logs backwards last week out of laziness but I won't be doing that anymore since there appears to be a weakness in the front end in that condition.
Thanks for the heads up and good luck. Keep us posted.
   / JD 790 front end problems #3
Sorry to read about your problems with the 790.
Kind of a done deal if the front differential spur gears are wiped...from what I've read on TBN, that's about $1500 worth of parts (IIRC).
400 lbs isn't much rear ballast (especially since the loader can lift twice that amount of weight). Are you sure that's all your loader manual calls out? I have a ballast box that goes somewhere between 500-600 lbs (sand is my ballast). You might even want a bit more...
Since you wrote you were pulling materials out of a pond, that suggests to me that when you reverse, you're going upslope thus a weight transfer to the front of the machine (putting more stress on the front axle gears.
After adding more ballast, you may want to consider chains on the rear tires for more traction (reducing the traction requirements of the front axle).
Are you using a tooth bar on your bucket? Going in with a standard bucket requires quite a bit of force to break into the materials.
Also, you've had the same failure...twice. Is there something in your technique that could be contributing?
   / JD 790 front end problems #4
Wow! This discussion is an eye-opener. I have put considerable stress on my '05 790 front 4wd parts without even considering that they would make this thing without the ability to handle the work! Time to trade for a real tractor if I have to start worrying about using the loader while in 4WD.
Thanks for your responses.
Tunguska, thankfully it was the two planetary type final gears at the very end right behind the wheel. Pop the wheel and pull the bolts and right there they are. Pull the whole unit down and you can disassemble the whole package (it requires a good bearing driver if you replace everything).
Roy, that is helpful to know on the weight issue. I am basing the 400lbs. on the mechanic who sat down with me in his shop and looked up the load ratings and counter balance. I called him back when I found that my boxblade weighed 418lbs., and he still recommended more weight in the back. I am thinking of adding two five gallon buckets full of sackrete on top of the box blade (?).
The tech said they had a rash of these problems back a few years ago when the 790 was an 870 or something like that and, after talking to the engineers, it was determined that there was not enough weight being put on the back to counter balance.
There is no question that the problem is my technique and application, which is almost impossible to avoid given our homestead typography and ponds, etc. Thankfully the bill for parts was not quite as bad this time (ca. $670 for both sides--gears on both sides, bottom bearings for both sides, and gaskets). What seemed to help was that I went to the JD website, searched the parts, put them in my shopping cart and printed it out with this local JD dealer as the dealer of choice (I noticed they were much less $ than what they had previously been). Evidently the dealership honors the price, which in this case was substantially less than what they charge if I just came in without the printout.
All things being equal, I suppose I should have the 990 or one of the 400 series for our property. But I love the 790 as it can literally get into places on my property and do things that larger ones cannot. In all other respects it is bullet-proof and only sips fuel.
I guess the only thing I can do is add more weight to the rear, really try to avoid backing up with weight in the bucket (this is going to be hard doing with some of my pond work), and keep it in 2 wheel when digging (to avoid that pawing of the tires and shock when it suddenly gains traction). I really do not see it as a fault with the tractor's design so much as I just have unique application needs that even the JD tech said would probably best be served with a bit larger equipment. I will give it one more season--if the same thing happens again, I will fix it again, and I suppose be forced to go to a larger tractor (which I hope to avoid--these things are not cheap!).
   / JD 790 front end problems #6
That was probably a 670 or 770, both of which are almost identical (except for engine and tire size) to the 790.
If you add more weight (remember, the 790 can handle 800 lbs on the 3ph), I think that will resolve most of your problems. As I wrote in my first post, add chains to the rear tires...should make a big difference in traction.
BTW, what tires do you have on your 790?
Hi, Roy. I have R4's. Funny you mentioned adding chains to the rear, because that thought crossed my mind (though I do cross my grass and concrete driveway when going to pasture areas).
But I do believe I will go ahead and try to cheer it with more weight in the rear first and a wise use of 4x4 in contexts that place all the stress on the front drive. I will give it a year with these measures (and any thing else you guys recommend), and then pull the gear cover in 12 months or so and inspect it to see if there are any problems and go from there.
   / JD 790 front end problems #8
I don't mean to question your mechanical abilities, but since you are repairing this yourself, are you sure it is assembled properly and no washers or snap rings aren't missing or misplaced? Also, are ALL worn parts being replaced? Have you shimmed relief valve for extra lift capacity? Just want to be sure you are covering all the bases.
   / JD 790 front end problems #9
I think the problem here is over stressing the front axle while backing up.
Gear trains are designed to be stressed in one direction-a pickups differential will take more strain going forward, less so in reverse, for example.
Our tractors, likewise, are designed so that the rear axle does 70-90% of the work, regardless of the direction the machine is moving.
The problem occurs when going in reverse with a load on the front end, the front axle is burdened with the majority of the load, much more than it was designed to take.
I'm thinking going forward into a pile of whatever with your loader should be fine, especially if you have a nice counterweight on your 3PH (keeping the load back, making the rear axle do most of the work).
Pulling a load backwards, uphill, with no counterweight, apparently stresses the front axle enough to break it. I'll not do it again.
Thanks, DW.
No problem, thanks for asking.
From my youth to the present I have developed a pretty good mechanical background in rebuilding engines and other systems (sometimes out of necessity, sometimes just for the pleasure of doing a restore). As long as I have a shop manual in hand (which is the first thing I get with nearly any auto or tractor), for torque specs. and other proprietary information, I am pretty comfortable. I never like to stop learning though (hence this post). I am pretty careful about accounting for washers, snap-rings, or even shimming if that is necessary (in this case it is not). I clean and check every bearing and check every seal (I replaced most last time just to be safe). The JD tech looked at the meshing surface of the failed gears I brought in and said they were making good, full contact. They simply failed due to stress.
You do actually bring something to mind that may be very significant now that I think of it. As a matter of fact, yes I did shim the hydraulic pressure about a year ago--not as high as most--stock is ca. 2000psi; I took mine to 2400psi. I wanted the increase primarily to get more breakout force with the bucket (digging). That weakness was very frustrating. The first time this gear failure happened, I reasoned that the increase in pressure may be allowing me inadvertently to carry bucket loads outside the design limits of the tractor, so I was very deliberate about putting it in 2 wheel after loading from a dirt pile. Perhaps that is still not enough. After all, when I remove sediment or dirt from the pond's edge and then back up from the pond (slight incline), it is not so simple to judge if you took "too much" relative to pre-shimming specs. So I think you are on to something there.
Accordingly, I do believe the first thing I am going to do in this repair (in addition to more weight in the back) is remove the shimming and bring the capacity back to factory specs. The loss--even in breakout force--will be worth it if the front planetary gears retain their integrity.
This may in fact prove to be one of the very reasons why JD purposely dropped the pressure on a pump and lines which are clearly designed to operate safely beyond their default setting. Their concern may have been the front 4x4 planetary gears (as per the previous comparable model failing when not having sufficient counterweight). This is beginning to make a lot more sense.
Hutchinson 10" Transfer Auger (A50514)
Hutchinson 10"...
2017 Case 1150M Dozer (A50514)
2017 Case 1150M...
2015 Nissan Frontier S Crew Cab Pickup Truck (A50323)
2015 Nissan...
Semi Roll-off 2 Axle Trailer (TITLE) (A50774)
Semi Roll-off 2...
KEWANCE 200 9' GRADER BLADE (A51243)
KEWANCE 200 9'...
Land Honor Quick Attach Rock Bucket (A50514)
Land Honor Quick...
