JD 790 won't turn
   / JD 790 won't turn #11
Mr. Ohm didn't just have a good idea, he had a law :^)
It is possible that you readings were indicating a good cable with the microamps of current from your volt ohm meter but when you tried to pull hundreds of amps through the bad spot with high resistance the voltage drop was too much to allow the starter to function.
Glad you found your problem and were able to fix it.
Happy tractoring, Alan
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
Terms and Conditions (A47477)
Terms and...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
