Hogfan1978
I put an older Kioti loader on my JD 850 (no power steering). After mowing for several hours and then using the loader to lift a few big branches to a burn pile, I felt the loader control valve and it was hot. It wasn't so hot that I couldn't leave my hand on it, but it was definitely hot. Is this normal?
I had a finish mower in the up position on the 3 pt. would this matter?
Also, in the owners manual for the 850, it states that id you install a loader you should use a 3 port valve: IN (pressure side), OUT (to the sump), and BYD (to continue to the 3 pt hydraulics). However, when I hooked up in this manner, the loader worked, but not the 3 point. Instead, I plugged the BYD port and just had pressure IN and OUT going on to the 3 pt.
Let me know if I'm messing up somewhere.
