JD 870 3-pt won't lower
   / JD 870 3-pt won't lower #11
One other place to check is to trace your 3 pt hitch hydraulic lines back to your control valve, or the tank (or both). Not totally familiar with JD, but my tractor's 3 pt supply line actually runs thru the FEL control valve thru a power beyond port. If yours has the same "plumbing" you may have a small clog in the return line, or the port at the valve.
Okay, I will check it out. Thank you.
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2020 JOHN DEERE 5125R LOT IDENTIFIER 24 (A53084)
2020 JOHN DEERE...
