JD 955 Died in Field
   / JD 955 Died in Field #11
If you had tried to crank the engine before taking off the POS terminal, then the warm terminal says that you have a poor connection. That may be your issue right there. Clean the terminal and put it back on.
   / JD 955 Died in Field #12
I had a similar problem on my 955. Will it run if you put the key to the on position and jump the starter solenoid? Mine was back feeding power through the relay for the glow plugs. I had the whole wire harness apart to try to find the short. I ended up just taking the relay out. I had to do something to the fuel shut off, but I can't remember exactly what I did. It had a dull illumination of the glow plug light in the dash with the key off. It was hard to see with the lights on in the barn. My problem became apparent when I needed a new battery. I put a new battery in and the next day, the new battery was junk. I cant remember exactly what I did, but it had to do with how the fuel shut off gets power. I sold the tractor, so I cant go look at it to refresh my memory.
***Start Code 10101*** Hour meter is very hard to read Manual coupler, 2-Speed, 66 Bucket, (A55851)
***Start Code...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A57193)
UNUSED FUTURE SB45...
12 ft Shipping Container (A55973)
12 ft Shipping...
