JD 955 implement pump (gear pump)
   / JD 955 implement pump (gear pump) #11
Can I simply plug a gauge into one of the SCV output quick connects and check the pressure that way (by operating the valve of course)? Or do I need to tee into a line somewhere?
If you do not have a QD fitting, you can also just disconnect a hose from
a FEL cyl and put a guage there. Those fittings are cheaper. You do
need to have the work circuit you use at the end of its cylinder's stroke
(extend or retract) so the RV opens. I also cap the open fitting to avoid
spills. Then start the tractor and operate the FEL valve.
I dont' have a loader (yet) so I'm just going to plug the gauge into one of the QD's. I have a bag full of the male QD's that I can just screw a gauge directly into.
   / JD 955 implement pump (gear pump) #13
Here is a picture of my gauge, couldn't post it earlier from work:
Well, the pump appears to be fine. I got the tractor running tonight and took an open ended hose and attached it one port at a time and flushed out all the SCV lines. Then I plugged my gauge into one of the ports and the gauge peaks a little over 2500 psi before the PRV opens and pressure starts to bleed down. If I continued to hold the valve open, the pressure would bleed down to about 2200 psi.
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
2018 John Deere 333G Track Loader (A53485)
2018 John Deere...
2024 Schulte 5026 Batwing Rotary Cutter (A55314)
2024 Schulte 5026...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
