JD 955 No Start
   / JD 955 No Start #1
trees132
Southeastern, MA
a few
Hi guys,
Could use some help:
We have a JD 955. Today it was shut down and then would not start, like the battery was completely dead. We got it started with a jump and ran for a few hours, then the same thing happened.
I tested the battery with a multimeter and it looks good with a reading over 12v. But I still cant get the starter to engage without jumping. Any thoughts?
Thanks!
   / JD 955 No Start #2
Battery cables? This happened to neon my 955. The positive cable looked good but it was rotted inside. Good luck
   / JD 955 No Start #3
How old is the battery? When I've taken batteries in for testing they do a load test. My guess is you need a new one. Take it out and have it tested though to see.
   / JD 955 No Start #4
Turn the key to start and shake the cable around. That's how I found out mine was bad
   / JD 955 No Start #6
That battery should be more like 12.6V after running for a few hours. Unfortunately, as already noted, without a load test, you can't really know for sure if it's good.
   / JD 955 No Start
Thanks. I will get the battery checked out and take it from there.
   / JD 955 No Start #8
Jiggle the battery cable and have someone else turn the key. If it turns over replace the the hot battery cable .same thing happened to me. Opened up the battery and found that it was all corroded.
   / JD 955 No Start #9
Poor man's load test. Take the multimeter and check between the big post on the starter and ground. Should be battery voltage. Now hit the starter. Does it drop to nearly nothing? If so, do the same checking at the battery. If it drops a lot, then bad battery. If not, check connections or cable.
   / JD 955 No Start #10
So did you figure out your starting problem?
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
Club Car 4x4 Diesel Utility Cart (A59228)
Club Car 4x4...
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
1995 John Deere 7400 (A60462)
1995 John Deere...
