JD 955
   / JD 955 #21
The listing for the 72" MMM does not have a link. Does this mean I can no longer get the operator manual for it?
John Deere Ag - New Equipment: Technical Publications - Publications Search
Also I don't see the Owner's manual in the link you sent. For starters that is the most important one I'll need. Am I missing it there?
Also, my serial # is 300903. I see multiple manuals for the engine guide for instance. 2 listings for the North America Tractor.
I also entered the part number and title for the MMM here and got no hits.
John Deere Technical Information Bookstore - Home Page
TITLE: 72-Inch Mid-Mount Mower - 855 & 955 Tractors
part # : OMM93936
Am I doing something wrong?
Sorry for the bad intel...I did not look into it further after I posted the link. At least you have the part number-hopefully a dealer can get them for you.
   / JD 955 #23
They are not very heavy. I used to move my 855 (with loader and backhoe) around on my old landscaping trailer.
Good tractor. I think you will like owning it. You will definitely want a loader though.
The 3pt hitch is on the small side. Only small attachments will work well on it.
What is your intended usage?
   / JD 955
Mow primarily, move dirt, landscape, etc. on my 4 acres. Soon I will buy 3-4 more acres adjacent to the 4 I currently have. I have a pond and the other 4 acres will need drainage added.
I might dabble in some small time gardening as well.
Did you like the backhoe on your 855? That would be nice to have.
I will definitely be adding a loader fairly soon. I wanted to buy a tractor with a loader, but I couldn't pass up the deal I got on this 955. Plus I can now mow with the mmm that came with the machine. I just bought the property at the end of this past summer, and was borrowing a rig the last couple weeks to keep it mowed/brush hogged.
I have access to a much larger tractor if I need it. I think this will suit my needs for 95% of what I will be doing.
   / JD 955 #25
The 955 is an excellent tractor. At 1970# naked, it is amazing that it
comes with a 33hp engine.
They are very reliable, but there are some weak points: the front grille
is hard to get on and off, and does not always stay secure. The PTO
gearcase is aluminum and has been known to break, but you should be OK
if you don't abuse it. The hour meter/tach is in the same guage, and they
fail. Fortunately, they do not cost too much. I found that the front axle
pivot is only a 1-inch shaft, and it is hard to grease. Finally, the x55
series has no foot clutch, so it has lots of interlocks, electrical, and
mechanical. One day, you will not be able to start your tractor, and it
will probably be due to a switch failing. My last 995, I mounted a hoe and
disabled all interlocks. Loved it.
As for loaders, don't forget to check an aftermarket supplier like Woods,
SMC, Westendorf, etc. I do see that Westendorf's TA111 will fit, and
I will bet that it costs less than JD's.
   / JD 955
Thanks for the suggestion on looking at other loaders. I will check into them.
   / JD 955
I just ordered all manuals owners, parts, technical, and mmm.
I had to call JD directly to order because the MMM wasn't available online. I had them put them all on the same cd. I prefer the digital format.
   / JD 955 #28
I say you got a great deal ! The loader valve is half the battle , These are great tractors, lots of grease fittings. I own the little brother a 755 ,with a 60 mmm and a 70 loader. Someone mentioned it before, but a tandem landscape or car trailer will get your 955 around nicely ! Just be sure to use some good chains or straps to tie it down
   / JD 955 #29
Cool, you will like having them, they are very well done!:D
   / JD 955 #30
Sounds like the 955 will be a great fit for your needs.
The JD#7 hoe fits the 955 and is a good match. It is wonderful for doing small excavating work, especially in tight quarters. It doesn't have a lot of power though so it is slow going if you have to dig out tree roots. I did a lot of that with mine. The 955 doesn't have enough weight or hydraulic flow to support anything much bigger. The sub-frame mounting works well and is not difficult to mount/dismount, once you get used to it. Don't get a 3-point hoe. They would likely kill a 955.
I dug a pond and canal with it and it worked great. I also used it for doing a bunch of rock work and for planting.
The 955 was hugely popular with local landscapers. It out numbered all the other tractors by a significant margin.
   / JD 955 #31
Did you ever check your hoe's relief valve setting? The 955 delivers an
excellent 2500 psi, and an OK flow of about 7 or so GPM. Even that 7 hoe
should have no problem dragging the tractor around.
   / JD 955 #32
Did you ever check your hoe's relief valve setting? The 955 delivers an excellent 2500 psi, and an OK flow of about 7 or so GPM. Even that 7 hoe
No, can't say that I did (but might have). So I might have been giving some away. It could move the tractor around, but that's a big part of the problem...the tractor isn't heavy enough so much of what you want to dig up becomes an anchor point to move the tractor :)
   / JD 955 #33
Does anybody know where I can find new or used tires for my model 770 J.D. tractor with a tire size of 11 x 17. The tire manufacture on the tires I have now is Firestone, but I cannot seem to be able to find this particular size. They are ag tires on the rear. I appreciate any info I can get.
   / JD 955 #34
That's great. You guys are awesome. I will be asking for advice on many things in the future. I'll post some pix up when I get the tractor home next weekend.
Ever post those pics ?? If so, pls point me in the direction they are. Thanks :)
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A60430)
2022 FORD F-750...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
2020 Deere 544L (A60462)
2020 Deere 544L...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
