JD drink holder on JD 4100 & moving clip
   / JD drink holder on JD 4100 & moving clip #1
garchib
southern NH
JD 4100 HST, Craftsman YS4500
I saw a picture of someone's ("kennyd"('s) ?? ) 4110 with a JD cup holder on their fender and decided to do the same. I put the cup holder in the same spot on the right-hand fender, but had to remove the seatbelt holder/clip (where you put the seatbelt when it is not in use). In the picture I saw, the person moved the seatbelt clip to one of the bolts that holds the ROPS on and I thought "what a good idea !". However, I cannot loosen that bolt to save my life and before I dig out the impact wrench, I figured I would throw this out to the TBN gallery.......has anyone else done this or am I being stupid to remove a ROPS bolt to move this seatbelt clip ? /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/confused.gif
Thanks, G
   / JD drink holder on JD 4100 & moving clip #2
It was probobly mine that you saw. The bolt is tight, but did come out. I had to ream out the hole of the clip a little to get the ROPS bolt through it.
Good Luck! /forums/images/graemlins/cool.gif
Thanks for your help and the idea /forums/images/graemlins/grin.gif
   / JD drink holder on JD 4100 & moving clip #4
How about posting a picture of this set up for all of us to look at?
   / JD drink holder on JD 4100 & moving clip #5
Click the link in my sig.
It is in there.... /forums/images/graemlins/wink.gif
   / JD drink holder on JD 4100 & moving clip #6
I was just thinking of putting that same cup holder on my 990 for a Gatorade bottle. My 4300 had a cup holder but the only thing that would fit was a can of pop not a bottle. How useless in the summer mowing and get dust in your pop. That cupholder that you are getting is the same ones used on the JD line of Garden tractors and it is adhesive so it could stick anywhere then you don't have to remove any bolts.
....unfortunately, there are not many flat spots that would
work on the 4100, except the hood /forums/images/graemlins/grin.gif
So, bolt removal is necessary
   / JD drink holder on JD 4100 & moving clip #8
Ah, I see now. Well, use a breaker bar and get it off!
"kennyd", I removed the bolt with an impact wrench and widened the hole in the clip, as you suggested. Thanks for your help, G /forums/images/graemlins/laugh.gif
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
