JD L120 vs L130
/ JD L120 vs L130 #1
rv4ator
I am considering purchasing a JD L120 or L130 mower. After looking at the specs, the only difference I can see is the engine. The L120 has a 20 hp Briggs V-twin & the L130 has a 23 hp Kohler Command V-twin. Is the Kohler engine worth the extra $300 price tag? Which engine is better/more reliable?
/ JD L120 vs L130 #2
I feel the kolar is a beter engine. I would sugest looking at the LT180 thuogh. It is only 17hp but the kawasaki is a better engine and you are getting a heaver frame and deck. will take the rugged terrain a lot better and last years longer. We have had quite a few L series back in for welding and adjustments. Just my two cents worth.
/ JD L120 vs L130 #3
The kohler is a heck of an engine for $300. I have the L120 in a briggs with 48" cut. I love it,I cut my time in half,literaly.I used to cut with a 44" craftsman gear and this L120 is like a cadilac. The mower was worth every penny and if I wear it out in 10 years, I can still buy another and not have paid as much as you would for JD's high end stuff.
/ JD L120 vs L130 #4
Go with the Kohler. I think it's a better motor and it is a heck of allot miserly on fuel. /forums/images/graemlins/wink.gif
/ JD L120 vs L130 #5
Go with the L130. The L120 with the Briggs engine has some issues with rough idling. It will idle rough at anything below 1/2 throttle and there is appearantly no cure for the condition other than not operating the engine under 1/2 throttle. The L130 Kohler is a much better machine engine wise. If you would like specific details you can PM me. Hope this helps!
2007 International Derrick Digger Truck (A60352)
2007 International...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
Crown SP3550H-30 Stand-On Electric Forklift (A59228)
Crown SP3550H-30...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
2004 Toyota Camry Sedan (A59231)
2004 Toyota Camry...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
