JD LT 160 stops when mowing
   / JD LT 160 stops when mowing #11
Ed22
If my memory is correct the lt160 does not have an electric pto for the blades,maybe I'm wrong .But if it is a lever which moves an idler pulley that tightens the blade/deck belt. Many times I have found that the engagement lever will wear the insulation off of ,or pinch wires when engaged /disengaged and ground out causing the engine to die. You may have found your problem with the wire that you already taped up. Check all of the wiring in the area and I think you will find your problem.
Regard's
Sean
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
Echo SRM2620 Gas Trimmer (A49462)
Echo SRM2620 Gas...
CATERPILLAR 299D3 SKID STEER (A51242)
CATERPILLAR 299D3...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
