jd lt 160 stuck oil filter
   / jd lt 160 stuck oil filter #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
Hi all,
i have a problem. The oil filter on my lt 160 is stuck. i cannot get it off, is there any trick, or way that you have found to get it unscrewed?
i have been using an oil filter wrench (one that tightens as you move the handle).
i have also tried using a pipe wrench but that seems to damage the outside of the filter.
the filter will not budge, either direction.
Please help my grass needs to be cut.
thanks
forgeblast
   / jd lt 160 stuck oil filter #2
You can poke a large screwdriver through it and use it for leverage. Or put some sandpaper between the filter and the filter wrench so it gets a good grip on the filter and then use an extension and the filter wrench. Or some large channel lock pliers...grip as close to the top as possible.
Thank You, im running to the barn now.
I really appreicate the fast reply.
forgeblast
   / jd lt 160 stuck oil filter #4
Somebody makes an oil filter "socket" that fits over the flat surfaces on the end of the filter and you then use a wrench on that. Be aware that there are different sizes so you need to get the one that fits your filter. They work really well.
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52128)
NEW Work Saver...
Wolverine Quick Attach Concrete Mixing Bucket (A50514)
Wolverine Quick...
2010 Toyota Corolla Sedan (A50324)
2010 Toyota...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
