jd lt 160 stuck oil filter
   / jd lt 160 stuck oil filter #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
Hi all,
i have a problem. The oil filter on my lt 160 is stuck. i cannot get it off, is there any trick, or way that you have found to get it unscrewed?
i have been using an oil filter wrench (one that tightens as you move the handle).
i have also tried using a pipe wrench but that seems to damage the outside of the filter.
the filter will not budge, either direction.
Please help my grass needs to be cut.
thanks
forgeblast
   / jd lt 160 stuck oil filter #2
You can poke a large screwdriver through it and use it for leverage. Or put some sandpaper between the filter and the filter wrench so it gets a good grip on the filter and then use an extension and the filter wrench. Or some large channel lock pliers...grip as close to the top as possible.
Thank You, im running to the barn now.
I really appreicate the fast reply.
forgeblast
   / jd lt 160 stuck oil filter #4
Somebody makes an oil filter "socket" that fits over the flat surfaces on the end of the filter and you then use a wrench on that. Be aware that there are different sizes so you need to get the one that fits your filter. They work really well.
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
