JD oil pressure problems
   / JD oil pressure problems #1
bugzey
how much oil presure should a 3020 have at idle ours has ) and has a low rpm knock I replaced the rod bearings but still has the knock
   / JD oil pressure problems #2
Welcome to TBN. :)
   / JD oil pressure problems #3
Howdy! welcome to the forum! :thumbsup:
Chek out the John owning operationg section.... Those guys can really help.. There is this one guy over there named Dcyrilc... hit him up for sure.. he likes oil problems!!!!
   / JD oil pressure problems #4
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the John Deere Owning/Operating Forum. You'll get a better response there. ;)
   / JD oil pressure problems #5
Did you check the bearing clearance before and after with plasti-gage?
by ) pressure, did you mean 0?
   / JD oil pressure problems #6
By "Low RPM"...how low is that? Diesels aren't fond of low RPM (except for shipboard diesels...but they'll built for it). Low RPM can result in the bearings pounding.
How are you measuring the oil pressure? And, is it within range at operating RPM and temperature?
I guess the first question should have been "Is this a diesel? Gasoline? LP?"
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2013 INTERNATIONAL REEFER TRUCK (A54607)
2013 INTERNATIONAL...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
