JD Water in Base - Need Help
   / JD Water in Base - Need Help #1
savoury7137
310 john deere
I w kind of trouble i am into I have a 310 john deere with water in the base and fomeing in the rad can anyone help me thanks.
   / JD Water in Base - Need Help #2
Welcome to TBN. :)
   / JD Water in Base - Need Help #3
Hello & WELCOME to TractorByNet.com! :)
I moved your thread to the Parts/Repairs Forum and edited your title to help you get a better response.
   / JD Water in Base - Need Help #4
Not sure what you mean by "water in the base", but if this means water in the oilpan or bottom of the engine and you also have foaming in the coolant water (radiator), it probably indicates a blown head gasket or a cracked head.
thanks for your help .
   / JD Water in Base - Need Help #6
if it's a 310 a electrolisis eats the cylinder sleaves if you don't keep good rust preventive in them
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A55788)
2014 Peterbilt 337...
43029 (A51691)
43029 (A51691)
