JD X485
   / JD X485 #11
Captain:
I run a X595. These X units have an issue with overheating. You should get a copy of the bulletin from JD on this issue.
Grass clippings, leaves, etc will get pulled up and clog the grilles at the rear of the engine housing, causing the temp to skyrocket. If you don't pay attention, engine damage can occur. Need to frequently clean the 2 sides and rear grills, and, mostly importantly the screen inside the cowling in front of the radiator.
jim
   / JD X485
Thanks RedHawkRidge. You may have saved me from some expensive consequences. The internet is a beautiful thing.
   / JD X485
Under the 30 day program, I turned in my X485 for a X585 and went for the FEL instead of the 54" blade. Will let you know how it works out.
   / JD X485 #14
Captain752 I will be interested in your thoughts on the X585. stopped at the local JD dealer yesterday with a ride mower in mind figuring on lawn tractor would still be a couple years out now. But the X585 w/ FEL wsa there and caught my eye. So I may be looking that route for a sub CUT with FEL and 54" mower and rear blade. But I need more info before I go.
   / JD X485 #15
Captain752 any thoughts on X585?
   / JD X485 #16
   / JD X485 #17
I have an x 485 with a bagger the 3 bag system only problem i have is it is very dusy can you use a blowout sytem with the bagger also or not
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
Utility Trailer (A52377)
Utility Trailer...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
40' CONTAINER (A51244)
