JD X595 Temperature AND fuel gauge go full scale when PTO is engaged.
   / JD X595 Temperature AND fuel gauge go full scale when PTO is engaged. #11
Thank you for your service.
   / JD X595 Temperature AND fuel gauge go full scale when PTO is engaged. #12
loose or corroded grounds.
Yep. Start cleaning grounds. Don't just look them over. Take them apart and clean them. Shiny metal to metal, and coat with dielectric grease before you reassemble them.
Don't forget the ground wires themselves, and the connectors.
   / JD X595 Temperature AND fuel gauge go full scale when PTO is engaged. #13
I had same thing with my x585. it was bad ground on the lift side of the plug where it plugs in to the dash. you must squeeze the two prongs togather in the plug to make contact. wiring harness is to heavy for the plug. harness must be puled up an tied fast so it donot hang on the plug good luck. it fixed mine . I went through the same soldering did not work. there two grounds in the plug its the one on the lift its black
2013 Mack GU813 Roll Off Truck, VIN # 1M2AX13C1DM019680 (A51572)
2013 Mack GU813...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A51247)
UNUSED AGT YSRT14...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
SCAN TO RECEIVE TEXT UPDATES (A51247)
SCAN TO RECEIVE...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
