jd z997 vs kubota zd331
   / jd z997 vs kubota zd331 #12
kubota has a 32 gal gas 3 cylinder zg332
wonder if I should b looking at a more horsepower gas than diesel
wonder if the zg332 would burn a lot more gas than diesel
Here are my opinions and experience with gas vs diesel..
I had a ZD21 (3cyl diesel) w/ 60" deck, it was equal on hp to a 25-27hp gas w/ 60" deck
The diesel was much much more fuel efficient than a carborated 2cyl gas engine.
A fuel injected gas engine will be close to as efficient as a diesel.
A 997 has a 31 hp 3cyl diesel, so you would need around a 35-37 hp gasser to be equal useable power, but the gasser will be not as efficient.
Diesel powered machine will cost more at purchase, fuel filters will cost more, and the engine will last far longer than a gas machine. Now, is the added costs worth the extra fuel saved?? Thats for you to think about. If your commercially mowing, I would go diesel, but homeowner, might want to stick with a gasser..
Are you looking for a 60" or 72" mower deck?
   / jd z997 vs kubota zd331 #14
I really don't think you need that industrial of a mower. I don't want to try and talk you out of it, but that's a lot of mower for a homeowner. I have a Deere 345 that I mow the lawn with, 12 years old and has about 750 hours. Our mowing season is short. As much as I would love the 997 it make no economical sense for me to pay $14k on a mower that will not drastically shorten my mow time and is much more expensive than a similar gas model that would go way longer than needed for a homeowner such as myself. If you really require diesel, go for it. But you don't need it and it will cost much more to own as a homeowner than a gas. Theres a big difference from me who cuts my lawn every week - week and a half in the summer to a lawn pro who cuts 25 acres a day. I'd really suggest taking a closer look at the gas models before you buy.
And Kubota Fan, the 7 iron deck is one of the best in the industry, if not the best. Really no deck compares. But you can still get the 7 iron in a gas ZTR.
i was considering the x749 also. what do you think. duznt have 7 iron deck and only 8.5 mph. dealer suggested x749
i have more cutting time during the year, i am having to cut grass now in february, cut a couple times in january. its ridiculous. too early to b cutting
   / jd z997 vs kubota zd331 #16
I would keep your BX, then no need for the 749, and get a gas ZTR with a 60" deck. Something like the Deere Z920A with a 60" 7 iron deck or comparable. It is still a commercial duty mower but list is only $11.5. Which is still a lot in my book. If your the type that has to have the greenest, nicest lawn in the neighborhood, I'd get something like the Z920A. If you just need to cut the lawn they make homeowner versions that will do the same thing, a little slower but will look and work just fine. Don't get to caught up in speed. Top speed doesn't matter as much as average speed. If you have a lot of trees that you can only go 3MPH around anyway, what will it matter to have the extra top speed. A lot of turning and such slows you down a lot as well. Unless you drive these every day as lawn pros do, you don't get the full use of the top speed.
I would look into the Bad Boy mowers (Bad Boy Mowers) Really sweet machines. If I were getting a ZTR, it would more than likely be a Bad Boy. Only wish it had Deere's 7 iron, but besides that, I like everything on the Bad Boy better, especially the price. A 'compact' CAT diesel with 61" deck starts at only $11.5. Have a lot of nice features like an air ride suspension and seat. Make a lot more sense when comparing dollars and sense. And up to 15MPH. Along with the diesels, I'd take a good look at the Outlaws, which are gas but very good quality. A buddy of a buddy sells them and has been trying to convince me forever. Next mower (be a while) will likely be a ZTR and more than likely a Bad Boy. The price is just so much better, and they have a lot of better features.
   / jd z997 vs kubota zd331 #17
How did cut quality compare between the Kubota and the John Deere? From what I have read the JD 7 iron deck gives a hard to beat cut.
The Kubotas I had cut very well!! I loved the machines, my issue was with the dealer. Had my 28 for a month and a half waiting on parts and doing the job, and when I got it back still wasnt fixed. As a commercial cutter, thats not good!
The top speed of the mower dont mean crap to me. Dixie Choppers run 15mph? Who cares. My deeres run like 12, but I only mow around 6 avg. Ground conditions tell how fast you run.
   / jd z997 vs kubota zd331 #19
Anyone know the depth of the deck, and if it's fabricated or stamped?
kubota 6.5"d fabricated
jd 5.5"d stamped
both 7 iron
CAT Skid Steer (A50322)
CAT Skid Steer...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
