JD300 transmission filter guts missing
   / JD300 transmission filter guts missing #11
I am not sure on your model but, the transmission pump is probably or more then likely a charge pump for your main pump hooked to your crank shaft. It may have a seperate feed for like power steering from the transmission pump. The transmission pump would be open center.
One clue to a closed center is the accumulater.
I would suspect you are right that filter was removed on account of cold weather.
2025 AGT QK16R Mini-Excavator with Dozer Blade & Hydraulic Thumb (New/Unused) (A59225)
2025 AGT QK16R...
2825 (A58376)
2825 (A58376)
SKID STEER ATTACHMENT BRUSH WITH BOX (A58216)
SKID STEER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
