texasjohn
Super Member
I have a Grand L 5030 with 853 loader, earlier model of the L5240. Several comments.
Best idea, try it with actual weight you wish to lift. Shape of weight, distance from pins makes difference.
You will absolutely need lots of rear weight, filled tires, etc. talking close to 1000 lbs, to SAFELY move max weight
Hydraulic pressure in my 5030 was under spec from factory, got it raised, made vast difference in lift capacity. Believe it.
Quick attach for bucket makes attachment a non issue.
I lift 2700 lbs to about 1 foot height with bucket detached, load chained to arms, then hydraulic relief valve pops.
Hay bales, large, heavy, tight, are easily lifted to max height, can stack two high...see rear weight comment!!!
