JD455 PTO
/ JD455 PTO #1
DeereBris
Brisbane
JD 455
Hello, I have an old JD 455 and the mid pto does not spin. I have installed a new PTO solenoid and nothing. I ran a mid PTO pressure test as per the manual and I received a 0 psi reading. I also did a pump test and the reading was ok. Does anyone have any ideas how I may diagnose this problem, it sounds very much like an electrical problem to me.
/ JD455 PTO #2
My 425 had same problem. Cause was a faulty ignition switch module. There is a relay on the circuit board that controls the PTO function.
New/Unused Wolverine Quick Attach Ripper (A61166)
New/Unused...
UNUSED 250 GALLON FUEL TANK (A62130)
UNUSED 250 GALLON...
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
5ft 3 Point Hitch Rotary Cutter (A61166)
5ft 3 Point Hitch...
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
