rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,656
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Which a bad VR can cause. If the vr is not cycling properly, the battery can indeed fail to charge. Headlights can also be dim and instrument panels can be wonky. The voltage regulator controls the flow of electricity to every working part, including the engine. Bad voltage regulators have been known to cause engine stalling, acceleration issues, irregular engine timing, and misfires.
At this point, i would take off injector fittings and see what I am getting as pump out volume.
I think you are missing something here. We are discussing an old style diesel - the JD750 - which is pre-computer, pre-emissions, and pretty much pre everything electrical. If the starter starts the motor, a failing voltage regulator my not allow the battery to charge, but the but the tractor will run just fine.
A bad voltage regulator on that model tractor - or any similar tractor from that era - will NOT cause engine stalling, acceleration issues, irregular engine timing, or misfires. None of that is electrical. Those are old style very simple diesel tractors. All of those systems are mechanical.
rScotty
