JD755 overheating final thoughts?
   / JD755 overheating final thoughts? #1
BigNotEasyGuy
Bennett, CO
John Deere 755
I have posted in this forum in the past and read everyone's advice which was very much appreciated. I had been debugging an overheating issue on my 755. I can't use my brush hog or mower deck for longer than a few passes before it heats up to ~220 and I see antifreeze coming out the overflow from the radiator. I replaced the thermostat, and because of another issue (my fault) I replaced the radiator and oil cooler as well. Now I have a head gasket kit because that is the last thing I figured it could be. This all happened because I ran it hot trying to plow a garden and it had a coolant leak and subsequently burned up oil. I have since learned how to check my fluids and have been maintaining it much better. But I believe I might have ruined the head gasket and it's leaking hot air into the water. There's no sign of water in the oil.
So with that backstory my plan was to replace the head gasket but people said I should check the oil pressure. I have watched videos of this but I see that I need a special adapter. Does anyone have advice on a pressure gauge and/or adapter to buy? Is the harbor freight version gauge ok? And is there a better place to get the adapter than john deere, it's a bit expensive (like all their stuff).
Second, I have seen people mention the water pump impeller. When I put the idle down to 1500 rpms it does start cooling itself down so I theorized that the water was circulating and that meant the water pump was working. But it does take a long time, it's quicker to turn it off and read this forum on my phone while I wait. Is there a quick check to confirm the water pump is ok? Some people say to turn it on, take the radiator cap off and look for bubbles or listen for hisses. That doesn't work, the engine vibration makes the fluid pretty disturbed and I can't hear anything but engine noise. If there are some old school tricks to confirm that the water is circulating let me know.
Other than that, does anyone have any videos or advice on changing the head gasket? I read the instructions online and in my manual but they are a bit simple. I have looked on youtube but haven't found a video of a 755 or similar tractor with this job. Maybe I'll film it even though I'm a novice. Everyone can comment on what I did wrong. :)
Any other thoughts or suggestions? I've done a lot of debugging on this overheating. By the time I hook up the brush hog and drive to the other side of my house to mow it's already up to 190. Then after 2 or 3 circles it gets to 220 and I turn turn it off to cool down. It takes me 3 cool down cycles to mow the leach field which seems wrong. I'm not doing this on a 100 degree day or anything.
Thanks for any last minute advice before I try to swap the head gasket.
-jasen
   / JD755 overheating final thoughts? #2
Good luck with the head gasket swap. Should be pretty straight forward.
Can you put a pressure gauge in the block in place of the pressure switch?
What is this "special adapter" that you mention? What is the Deere part number that is so expensive?
   / JD755 overheating final thoughts? #3
I had major overheating isses with my Kubota Loader. Removed the RAD and gave it a thourough cleaning inside and out. Outside mattered more, I think. Problem solved, Cool as a cucumber in this heat wave.
   / JD755 overheating final thoughts? #4
Infrared thermometer reading various points in cooling system should tell you if coolant is circulating. Smelling your overflow bottle for hydrocarbons should tell you if head gasket is allowing combustion gasses into cooling system. Typically a head gasket leak causes pushing out of coolant or combustion bubbles in overflow. If none are present I would suspect a circulation problem in cooling system. Radiator and thermostat is new so all that's left is poor water pump performance caused by cavitation of impeller or cooling blockage in engine?
   / JD755 overheating final thoughts? #5
I am not trying to be doom and gloom but when you said it overheated and burned up oil there is a chance of major engine problems. If you are lucky just a head gasket. Could be a warped head. Worse case the engine is badly damaged, bad bearings, needs a total rebuild.
   / JD755 overheating final thoughts? #6
While you have the head off take it to an automotive machine shop and have it checked for flatness. This will tell you if it was warped by the heat. Flush and reverse flush the block as well as the radiator. That may not remove all the gunk but it will take out the lion's share. Depending on construction and how far you want to go, if you remove the radiator you may be able to pull the water pump and inspect the vanes. Check it for easy spinning as well. While you were running are you sure your fan belt was tight? If you remove the temperature sensor a mechanical gauge should screw right in to replace it. The challenge will be mounting a gauge.
Sorry, I was confusing terms. I don't know how to check the oil pressure. Any pointers on how to do that would be appreciated.
I actually meant to describe my research on how to do a compression test. I found a harbor freight kit for $30. Hoye Tractor Parts has a guage and and adapter for $80. The adapter itself is $23 which isn't that bad, I think I misremembered the price. I watched a youtube video showing how to check compression on a john deere lawn mower and they had several specific john deere adapters so I was assuming i'd need one for the 755.
Yah, that's my fear too. I'm guessing a compression test would help figure that out? The consensus from my last post was to try the simple stuff first. Since I don't see oil in the water I was hoping it was just the hot gas heating the water preventing cooling from working effectively. Do you have any suggestions on tests to run to figure that out?
Does 'RAD' mean radiator? This behavior existed since my plowing debacle and then I punctured my old radiator lifting a square hay bale (long story). I had to find another radiator and I swapped it out. The replacement was used but very clean. I get the same behavior after the swap. Since this happened right after the overheating incident while plowing and didn't behave this way before I assume I caused damage somewhere and I'm just trying to figure out where.
Thanks for the tip!
Oh, a thermometer, that's a cool idea (no pun intended). I see there are some at hardware stores for about $30, do you think one of those would work? I have one in my medicine cabinet but the range isn't high enough, (unless I want to check the JD for coronavirus).
So this tractor doesn't have an overflow, it just has a tube out of the cap that drips onto the axle when it's hot. But if I was going to check with a thermometer where would you suggest I check? I'm thinking inside the cap, maybe the in and out hose in the radiator? The out should be much cooler than the in I would hope? Any other thoughts?
I haven't figured out if it's easy to check the water pump yet. People seem to think the head gasket job isn't that big of a deal so maybe at the same time I could get to the water pump? I'll have to research that a little.
2015 Ford F 250 4x4 Ext. Cab Flatbed Truck (A44571)
2015 Ford F 250...
2012 Chevrolet Impala Sedan (A44572)
2012 Chevrolet...
2014 Dodge Charger Sedan (A44572)
2014 Dodge Charger...
2017 Ford F 550 Mason Dump Truck (A44571)
2017 Ford F 550...
2025 Wolverine ADB-13-1218R Auger Attachment (A47484)
2025 Wolverine...
2016 Ford F-550 4x4 ETI 37ft Bucket Truck (A44571)
2016 Ford F-550...
