JD790 loader
   / JD790 loader #11
John, unless you specifically need a narrower bucket, I'd go for the 60" to cover your tires. I've got the 70 loader with 60" bucket on my 790 and it's a mean, green digging machine /w3tcompact/icons/smile.gif
   / JD790 loader #12
My 2 cents is to get the wider bucket. I'd think you would at least want the bucket a few inches wider than the machine. Can't think of any reasons to get the narrow bucket if the machine will handle the larger one, which yours would.
Chris
4400HST, Canopy, 72" Deck, 516 Cutter, 420 Loader, 6' Blade, Homemade Sprayer, Boom Blade
1958 JD 620 Restored
   / JD790 loader
I called the dealer. The 54 inch bucket is $35. extra and the 60 inch is $55. extra. Since cost is not an issue, I think I will get one bigger than the standard 4 foot bucket. The rear wheels are 5 foot. My only concern is that I assume with a smaller bucket I could do a better job pushing into a pile of material. Of course, this could just be my newbe thinking. Better to make the right decision now when the cost to upsize is cheep. John.
   / JD790 loader
I did it. Ordered a # 70 loader with 54 inch bucket and bucket level indicator. I ordered an operators manual for the loader before I pruchased. The manual talks about 700+ lbs. of weight on 3ph, weights on rear wheels and loaded tires. Is all this necessary? For the guys with 790's, how much weight do you use and where do you put it? John
   / JD790 loader #15
To expand on my above post - when I first got my JD790 (like to call it that because everyone thinks that I have one of the big hoes, and to be its my big hoe, better than a shovel) I had no weight on the back, and no tooth bar, really had trouble digging, wheels would spin very easily when trying to dig. Could only skim off the dirt in thin layers. Got a tooth bar and it helped the digging, but the wheels would spin easily. Purchased a Bush Hog 5' box blade, about 490 pounds, added it to the 3 point, really made a difference. Also found I needed weight for keeping the rear wheels on the ground with a bucket of wet dirt or manure. Later purchased a Bush Hog 7' scraper blade, tried it, found it to bulky hanging out back, but it did about as good as the box blade. Purchased a Worksaver Fork attachment this summer, found the box blade was not enough when lifting at full capacity of the loader, so I loaded my rear wheels (R4's) with 5 gallons of methanol and 28 gallons of water each, giving me about 260 pounds in each tire. This is great, sorry I didn't load at the start - able to dig with out the box blade, and with the blade this thing really hugs the ground and will cut more than it can move. So my recommendation is load your rear tires, then look at implements with weight that will also be of some use to you.
By the way it only cost me $14 for the tool at NAPA (adapts garden hose to valve stem) and $40 for the methanol to load my rear tires. Cheaper than any implement.
   / JD790 loader
The dealer finally got my new loader installed and delivered it yesterday. It was here when I got home from out of town. Played (worked) all day today. Now I know why everyone with a FEL says they could not do without it. BTW I know in the last 73 posts I have asked many more questions than I have answered. Thanks to all you guys for the information. I still consider myself a newby. John.
   / JD790 loader #17
Way to go John. Yes, I bet you're loving that loader. I've been a bit tractor-deprived lately (busy) but I did use my FEL to take the fifth-wheel hitch out of my truck yesterday. Didn't take long, but I was all smiles for those few minutes /w3tcompact/icons/smile.gif
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2017 TOYOTA TUNDRA (A52472)
2017 TOYOTA TUNDRA...
1992 JOHN DEERE 544E (A52472)
1992 JOHN DEERE...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
