JIC fittings?
   / JIC fittings? #11
The only way to identify your connection with 100% certainty is to disassemble it. That said, the fittings do look like JIC from what you've shown us. Especially the second picture, which appears to a male fitting and flared tubing with a tube nut and sleeve.
Once you've taken the fittings apart, they should like the ones shown here:
JIC 37ー Hydraulic Tube Fittings > Discount Hydraulic Hose.com
The next step will be determining the correct size, which you can do by measuring the threads and comparing with the reference tables here:
Thread Size and Identification> Discount Hydraulic Hose.com
   / JIC fittings?
Can anyone tell me by looking at the attached pictures if these are JIC fittings? They are both on our BX23. The first is where the hard lines change to the hoses for the curl cylinder. The second picture is where the hose goes into curl cylinder.
In case the subject ever comes up again I took the hose pictured in the original post off and took it to a hydraulic shop. They are 3/8" JIC fittings on a 1/4" hose. With this information I hope to get the hydraulic parts ordered for my grapple in the next couple of days.
A Metcalf
   / JIC fittings? #13
Very good. Sometimes you just have to take things apart
2124 (A58376)
2124 (A58376)
1999 FREIGHTLINER FLATBED (A58214)
1999 FREIGHTLINER...
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2018 Honda ATV (A56859)
2018 Honda ATV...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
